Old 05-03-2008, 10:26 AM   #5 (permalink)
jbbets
Re: amp is hissing all over the place!!!
Originally Posted by t22a80
It sounds like alternator whine. Did you grind the paint away at your amp ground? Also are you using a LOC or a aftermarket HU? If you are using an aftermarket HU you might need to re-ground the HU because the nissan wire harness is funky. The ground in it sucks.
Man, I took the rest of the night off, was out there till like midnight. t22, I didn't grind the paint away from the ground, which I grounded to the bolt hole for the passenger seat.
also, I have a pioneer HU, so are you saying that I need to find the ground for the HU and ground it somewhere else other than in the wire harness??
thanks for your help so far, I'm ready to hang it up if it doesn't work right, which I can't figure out why!!
jbbets is offline   Reply With Quote
