Old 05-03-2008, 11:55 AM   #11 (permalink)
Nissan Mike
Nissan Mike's Avatar
Re: Fix for air pressure sensors??????
Originally Posted by maddozer
I have 35 toyo M/T's and from going back and fourth from the dealer to the tire shop making sure all sensors were working and having the system reset. The end result that the shop and the dealer came up with was that my tires were to thick for the computer to get the signal from the sensors.
Too thick for the sensors to read???
I'm sure there are a few members running 35" Toyo's without any problems.
Alot of tire shops are breaking the sensors dismounting the tires.Nissan came out with a TSB instructing that once the outer bead of the tire is broken loose,to unscrew the sensor and let it fall in the tire before removing the tire from the rim.Alternately when reinstalling a tire,once the tire is on the rim,screw the TPMS back on before sealing the bead.Maybe your sensors got broken on removal/install?
