Old 05-03-2008, 06:28 PM   #22
bdmpastx
Send a message via Yahoo to bdmpastx
Re: Bagging a 2008 Titan
Originally Posted by [SC]Titan
in about a year you're gonna want to body drop it
The body is already touching the ground in the rear. The floor in the rear was raised to accomodate clearance for the gas tank as well as the frame being modified to lay lower. If you look at most crew cabs, they sit higher than mine due to the frame piece that extends down under the cew cab portion and the tranny cross member. I'll post more pics up sometime next weekend. The front is resticted by the oil pan. I would need to have that fabbed up or raise the motor up in the frame, but then the hood would need clearance. It's a never ending battle I tell ya. Everything so far is back to looking factory. It isn't the cut up mess you see in the pictures above.
bdmpastx is offline   Reply With Quote
