Old 05-03-2008, 08:34 PM   #12 (permalink)
Burgy
Burgy's Avatar
Send a message via AIM to Burgy
Re: transmission flush or NOT!!!!! !??????????
I think it should be mentioned that there is a difference between POWER flushing and a simple flush. Chain shops will POWER flush a trans using fluid and possible cleaning agents. When my dealer did my Pathy they used a machine that simply reclaimed old fluid while returning new. The trans did the actual pumping, there was no additional stress on the system and now chemical cleaners added.
Trans worked perfectly with never an issue.
The method my dealer used is similar to what you could do in your own driveway.
Burgy
(Kevin)
08.5 Titan CC SE 4x4
Burgy is offline   Reply With Quote
