Re: Professional TIPS and TRICKS
Originally Posted by Skyboi
Dressing the underside of the truck will only nmake sense if you going to "show it" let's say at a car show. Other than that, if your looking for protection, A commercial undercoating would be the answer. The silicone or oil/water based dressings would have the opposite effect. They would collect dust and dirt. Then when that dust and dirt got wet it would act as a sponge holding the moisture to the frame then creating an accelerated corrosion
In potential problem areas my advice is .... CLEAN and DRY
God luck, hope this helps
I like to use PB Blaster or WD-40 under my truck. A buddy of mine uses the silicon dressing. He said he's been doing that for years with no rust.
2004 SE KC 4x4 Titan
B & B Exhaust
Volant CAI
Stillen S/C
Stillen Headers
TruTrak
IPT VB
IPT TC
Uprev ECU
