Old 05-05-2008, 08:39 PM   #4 (permalink)
Hawaiianbasshead
Hawaiianbasshead's Avatar
Re: Any1 thought of Airbags
you can't lift that high without it hitting the coil bucket even w/aftermarket arms I don't think, you'd be really close. at least it wouldn't be very drivable... PRG has a spindle lift which is pretty inexpensive and it lifts the front 4", so the airbag could take it to 6.5" I guess at least 6" since you can add a little on top of the spindle lift, not sure if it can go more than 6" though so you may need a 2" bag... you'd need to get more lift in the rear unless you want the front sitting higher than the back by like 4" or so... why bags? if you set it and change it alot your wheels will probably wear really fast at the edges and that'd cost more than it's worth to be adjusting the height all the time imo
