Re: Titan Vs F 150
maybe you dont understand correctly? what makes a truck have the abilities to pull heavier loads? torque and gear ratio? right? ok thought so. well how is it you think your f-150 can tow more than a titan? it has less torque and smaller gears and 1 less gear in the transmission. making sense yet, probably not cause obviously you have yet to be in a titan with a load on it, cause i will stop better than your ford, pull better and will haul more than what your ford will haul. like i posted earlier, you can take your ford and load it with whatever weight and ill add 1000lbs to it and take it up the same grade with the same or less effort, lets put the brakes to test, motors, transmissions, rear ends all to test. mine is a non big tow pack and i will beat your ford in any aspect of performance from, pulling, to just flat out race, to racing with a load. any of them the titan is better. and side air bags dont matter to you? wow guess your wife or kids arent worth anything consider the high roll over rate the f-150's have. hmmm pretty ****tty to me that you dont care about safety of you or your family in the vehicle they ride in.
"PIT CREW"
mods wanted:
stillen supercharger
uprev ecu flash
125 shot of nx
big brake upgradE
steel braided brake lines
master cylinder stiffner
REMOTE START
RHINO LINER
TRANSMISSION VALVE BODY UPGRADE
TRU-TRAC
MODS DONE!
8000k HID CONVERSION LIGHTS, REMOVED ALL THE DECALS,TINT, CAI, straight pipe exhaust, 38.5x14.00x17 procomp extreme at's, prg uca's, radflo rear shocks, deaver springs, prg's c/o's, 3 IN BODY LIFT, HITCH, KENWOOD IN DASH DVD 7" MP3/WMA/CD/, 1 15" KICKER SOLO BARIC L7, CRUNCH 1500.1 AMP, THROTTLE BODY SPACER, PAINTED INDIGO BLUE INTAKE COVER,BURNOUT MOD,LED 3RD BRAKE LIGHT,LED TAIL LIGHTS, CCFL HALO PROJECTOR HEADLIGHTS, BLUE LED'S UNDER DASH, WHITE FACE GAUGES, BLUE LED DOME LIGHT
