Thread: Titan Vs F 150
Old 05-06-2008, 05:32 PM   #30
rtc1184
rtc1184's Avatar
Send a message via AIM to rtc1184 Send a message via Yahoo to rtc1184
Re: Titan Vs F 150
since you keep repeating yourself that you dont own a new ford then obvioulsy you own an older model ford, that is like comparing apples to oranges retard. if you want to compare your old for to something ill compare it to my weld truck, want to compare those? hell we will even compare towing to my weld truck, what does that prove, i promise you your truck will not out tow or carry a load heavier than my weld truck. 350ho motor puttin 485hp and 596ft lbs of torque on 4.56 rear end with a grandma 4 speed manual transmission. sorry you will lose your pride on that one. also the newer ford does not have a better safety rating. they are the same in the front crash rating and titan is higher on the side impact and also less likier for a rollover.
"PIT CREW"
mods wanted:
stillen supercharger
uprev ecu flash
125 shot of nx
big brake upgradE
steel braided brake lines
master cylinder stiffner
REMOTE START
RHINO LINER
TRANSMISSION VALVE BODY UPGRADE
TRU-TRAC
MODS DONE!
8000k HID CONVERSION LIGHTS, REMOVED ALL THE DECALS,TINT, CAI, FLOWMASTER 40SERIES MUFFLER W/TURNDOWNS, 8" SUSPENSION LIFT, HITCH, KENWOOD IN DASH DVD 7" MP3/WMA/CD/, 1 15" KICKER SOLO BARIC L7, CRUNCH 1500.1 AMP, THROTTLE BODY SPACER, PAINTED INDIGO BLUE INTAKE COVER,BURNOUT MOD,LED 3RD BRAKE LIGHT,LED TAIL LIGHTS, CCFL HALO PROJECTOR HEADLIGHTS
rtc1184 is offline   Reply With Quote
