Re: A grave accident
Um, you don't have much of a choice if your Titan is your only means of transportation. There have been many discussions in this and other forums regarding the use of non-Nissan ATF. In most cases the conlusion is that you should stick with the Nissan Matic-J fluid.
I don't know anything about the RP ATF. If it was me and all I had available was the AMSoil ATF I probably wouldn't think twice about it.
«ClearBra, Leer 100XQ, MM SI9500 Winch, Airaid TBS, Volant PowerCore, AMSoil in everything but the transmission»
«SAW Coilovers and rear shocks, PRG upper control arms»
Jim
