Re: Roadmaster Active Suspension = AWESOME!
Originally Posted by Quartz
So let me see if I get this right. If I install this it will help with axle wrap. It will raise the back end of my truck about and inch but it will help keep it from squatting when I put a load in the back. It makes the truck ride better. I can adjust the ride stiffness. Is this all true?
What is the downside? It is difficult to adjust the ride stiffness? Is it something that you can easily adjust when you fill the truck with a load of stuff on the weekend and back to normal when the weekend is over?
yes it helps greatly with axle wrap
they say it won't raise you truck but mine did (then again I got the XXF kit)
The back hardly moves at all anymore, very rock solid and almost sports car like in the turns.
There really is no way to adjust the stiffness except to not pre tention the spring as much but you really don't feel it ride any rougher just better.
There really is no downside to this product that I have found as of yet.
will help you tow better, prevent axle wrap, definately a sway bar attribute and its an incredible invention.
edit: in fact I only feel it when I am cornering and it is just the sway bar attribute. I don't feel it at all in normal driving unloaded. I haven't had a chance to load it down yet to see how it feels loaded but I am going to be moving some things out to storage soon and will keep you updated.
05 LE Crew Cab Smoke OR 4x4
airbox mod with K&N
Scangage2/blendmount
future mods - JBA Evol  , PRG leveling kit, 2* timing advance, Injen Powerflow, and more
