Originally Posted by rtc1184
wow your truck has lived on 13psi of boost? impressive. the stillen supercharger is only 5psi boost and makes 167hp for the titan if my calculations are correct 167 plus the 317 stock makes 484hp on 5lbs of boost so i dont think someone getting 508rwhp is alot considering the things he did to get the. cams s/c and exhaust on an 06 titan would easily make 508 rwhp so that isnt a comparable statement.
Your math isn't correct, adding a gain to a flywheel number to come up with what? Come on. And that 508 rwhp and 618 ft-lbs SAE was made on a tuned 9 psi turbo kit with an engine that was 100% otherwise stock. Using your math that would be 578 hp and nearly 700 ft-lbs...but I know better.
and as far as the rearends go they have had issues cause the truck debuted in 04 when did ford debute? and they still have the same issues, recalls on the 6.0 diesels.
How do you go from rearends to 6.0L diesels? There are recalls and TSB's on every vehicle but I've never seen new-in-the-box rear axle assemblies stacked up in a dumpster. That pic was posted on these forums somewhere...
i am not a fan of dodge, but when it comes to motors dodge will eat the ford market on hp and torque so if it came down to it i would take dodge making a motor for the titan vs chevy or ford, but you keep buying your ford,
Dodges are good on paper, and it ends there. Too many restrictions with the engine management system to push them as far as they could be (now why does that sound familiar?). They don't have the aftermarket like GM and Ford though and as such I haven't seen a DCX Hemi Ram make 800+rwhp/900+lb-ft with ANY combination of parts. I've seen Ford and GM trucks make those numbers though.
i have owned all of them ford, dodge, chevy and now nissan and imo personally my 07 titan has out performed and durability than any of the other ones. i drive the crap out of my truck and not a problem one yet, knock on wood. so i am completely happy with the performance of my truck in all aspects and especially for the price. something ford can not even come close to touching.
Gee...I've owned GM, Dodge, Chevy, Nissan, Toyota, and Ford and all have had their pros and cons. I can say the Ford has not had a problem that I didn't cause though and it's put up with plenty of abuse. I'm happy with what I buy just as you are.
