Re: Mods to Safely Upgrade Towing Capacity?
The only way to make the Titian safe to pull that length is to cut the frame and weld an extension on so that you could have a longer whell base. I have a 30 ft. Sandpiper with simular weights and have a dual cam wt dist. system. Have not been able to get sway out no matter what. I was like you and thought only of weight to pull and not length. No matter what mods you do, it will not be safe.
