Re: How tall are the bump stops on PRG's 2.5" leveling kit?
They're about 2". Just figure that lifting 2.5" would likely require 2.5" more bumpstop to retain original stop position unless there's some sort of geometrical disportion involved. So, you should be fine with 2" stops, that's plenty of cushion to keep the metal from clanking together, right???
2005 Armada LE 4x4 - 2* Timing Advance - AirBox Mod - PRG Mini-Lift - Nitto TerraGrapplers 325/60-18
_____________
. Check out my Gallery! .
