Thread: Titan Vs F 150
Old 05-09-2008, 03:56 PM   #59 (permalink)
Blown330
Blown330's Avatar
Re: Titan Vs F 150
Originally Posted by TitanGreg06
Why does it matter if ford has more off idle torque if they cant get it to the ground? Have you seen what stock F-150 dynos? Its sad, really sad for pick up. The Titan gets it power to the ground (where is matters). You said dodge looks good on paper but then you go a quote what ford says on paper? The Titan out performs the F-150 in the real world case closed, nothing you can say will change that till ford learns how to build a truck.
Where the hell did I quote what Ford says on paper? Only sources I've used are Ford's and Nissan's advertised ratings and I QUOTED Popular Hot Rodding. Have I disputed that a Titan is quicker than a F-150? No. How about you not put words in other peoples' mouths. Ford knows how to build a truck they just haven't suited it with engough engine. That will very soon change though and you'll see what a large bore, over-square Modular can do. As for power to the ground issue, the damn trucks are turning the most over-built rear axle available in a 1/2-ton truck. If Ford had put 8.8's behind the 5.4's then it would be a different story (probably very similar to the Titan's story at that). I personally don't mind as I like the fact my stock rear end can take the abuse of launching a 5,000+ lb truck making 476 lb-ft of torque at the wheels on drag radials...
2000 F-150 XLT SuperCab
370+hp/450+tq SAE and not on the meth...yet...
Blown330 is offline   Reply With Quote
