Old 05-09-2008, 08:23 PM   #2
helomech
helomech's Avatar
Re: Loose parking brake
Put it in gear and set the brake, if it doesn't move it is probably fine. If you want to adjust it it is very easy. Look above the pedal, up under the dash. You will see a nut, I think 10mm just tighten that nut until it is like you want it.
