Re: Loose parking brake
Use a 10mm deep socket and ratchet to adjust the nut on the park brake. It's located just above the pedal. Adjust it while it is released. Tighten it a little then check it. After each time start the truck put it in reverse and set the brake. Let off of the brake and if the truck moves then you need to adjust it more. You should only have to push the park brake pedal half way down for it to hold.
