Thread: EVAP Large Leak
Old 05-10-2008, 11:55 AM   #14 (permalink)
James Con
James Con's Avatar
Re: EVAP Large Leak
Originally Posted by mcclintock89
thanks for the info, yea i went through the gas cap part already and a few other things but the code kept coming back. if my valve is bad and need replaced is there anywhere that i can purchase this part outside of the dealer?
http://www.courtesyparts.com/ Has them, Part # 14935-AM60A ( valve) is $75.00 and Part# 50790-7S01A (filter kit) is $81.96. Do you have the filter installed on the Truck already ? If so you might just need the valve. Why don't you try cleaning the valve first and see if it fixes your problem. If it last a little while longer without the code popping again then you nailed the problem. But eighter way you should have the filter kit installed as per the TSB. Don't forget to put a drop of 3in1 oil on the solonoid shaft thats what is gonna keep it from hanging up. Good luck let me know how it turns out.
AEM CAI, 18" Magnaflow
James Con is offline   Reply With Quote
