Old 05-11-2008, 07:28 PM   #2
HRTKD
HRTKD's Avatar
Re: Tires Wearing Unevenly...Help!
I believe negative camber would cause the outside of the tire to wear out prematurely. If the front suspension was changed without getting it properly aligned then I can see where you would trash your tires. After I added my PRG UCA's and SAW coilovers I had an obvious negative camber. An alignment with the alignment bolts (at extra cost) took care of it.
It doesn't sound like you have lower control arm problems. But if you find that your truck pulls one way or the other you could have the problem outlined in this thread.
«ClearBra, Leer 100XQ, MM SI9500 Winch, Airaid TBS, Volant PowerCore, AMSoil in everything but the transmission»
«SAW Coilovers and rear shocks, PRG upper control arms»
Jim
