Re: HELP! Camber bolt stuck!
Originally Posted by Blackbeauty
Find someone with some mechanical skillz who actually knows what they're doing...  -BITE ME BB!
Did you actually take the nut off the other end of the bolt?  -AHH..... YAH!
Did you totally lift the truck off the ground? - YEP, UP ON THE LIFT.
Did you take the wheels off to minimize overhang load on the front axle? - WHEELS AND SPINDLES!
Are the bolts rusted? Any visible rust at the edges of the bushing?- DUH, I LIVE IN NH!!
Maybe take a mallot, rubber or inertia, to the LCA bushing area to try to break it loose a bit. Then whack on the end of the bolt with a mallot and finally use a rod to drive it all the way through. - I TRIED ALL THAT!
One thing you might try, and it helped with my removal. Get a ratchet strap and attach the LCA on the side you're working to the frame on the other side of the truck and Titan it down. This will keep the LCA from "sliding" towards the wheel and putting undue pressure on the bolt.
It seems you just have a tough bolt there.... Good luck.
THANKS!
I REPLIED TO YOUR COMMENTS IN CAPS! HAHA
PRG said I'll probably have to try and cut the bolts! I called the dealership, FYI lower control arms are 200 bucks EACH!!
Chad
AKA "Mini Whore™" And now AudioWhore™
MODS: CST 7" lift, PRG UCA, SAW coilovers, SAW rear shocks, Deaver spring pack, PRG blocks, MotoMetal 951's 20x9, Mickey Thompson 35x13.5 Baja ATZ, S&B intake, Flowmaster Delta 50 muffler, Borla tip, 2* timing, projector lights, HID conversion (fog and low beam), Eclipse CD5000, 2x Arc Audio XXK-2500's, CDT speakers HD-M6 mid, braxial mount DRT-26 tweeter, Upstage 500XT, ES-01 tweeters CL-6x (rear fill), HD-10" sub, Tech12volts box, Kicker wiring, Ramatt sound deading, Active Tuning grounding kit. More to come!
Here is my friends Rav4 for comparison. The first pic doesn't do the lift justice!
