Re: HELP! Camber bolt stuck!
yes, you will have to cut the bolts.... its due to the salt from the roads.
We did a pro comp install a few weeks ago, and had the same issue....
Cut the bolts, then took the A arms to a machine shop, and had them put them on a drill mill, and drilled out the remaining pieces of the bolts.... A Arms went back on nicely after.
We even tried a 12 ton press, and then a 72 ton press!! The drill mill was the last option.
Born on: 4/11/2005
Signed: 5/21/2005
Delivery: 5/23/2005
05 LE Crew Cab 4X4 SMOKE
Off Road, Big Tow, Navi, DVD, XM, Sunroof, Underseat Storage, Bed Divider, Bed Extender
Aftermarket:
Husky Liners, ActiveTuning Grounding Kit, JetTech Spring Helpers (currently removed), Undercover Tonneau, Lund Interceptor, Wade Window Visors, Fram Boost, Bushwacker Fender Flares, CompuStar 2W900FM-AS, 2* Timing Advance, Siemens HKW-700 Bluetooth Car Kit, Two 11.Kv.2s running of an eD NINe.1 in custom BWR boxes coated with bedliner, 4" PRG Perf Package (SAWs, PRG Arms, 1" Deaver Pack, Bilsteins), 20" Axis Titan rims w/ 33" Nitto Terra Grapplers
Coming Soon:
another new rear end.. haha
trutrac
trac bars
power steps
custom 12" fiberglass sub-box (thanks rcantu!)
Exhaust
