Re: Tires Wearing Unevenly...Help!
Go to the DEALER to have it aligned, the tire shop adjusted your toe wrong and the dealer charges only $75.
For some reason, road force pushes our tires back more than most other trucks (maybe due to softer more flexible suspension??) so our Toe MUST be set close to all the way to the inside of the green on the OEM Specs. Tire Shops do not usually know this and they usually try to set our toe to '0' and the road force pushes them outwards and then the center of your tires wearout like you're describing.
2005 Armada LE 4x4 - 2* Timing Advance - AirBox Mod - PRG Mini-Lift - Nitto TerraGrapplers 325/60-18
_____________
. Check out my Gallery! .
