Originally Posted by my06titan
Thanks for the response guys. What do I replace the CST carrier bearing bracket with? Also, i remembered when Greg installed the CST carrier bearing bracket, he cut a piece of the truck cross member piece.
Thanks again for all of your help.
Go to a hardware store and get a piece of 1/4" steel plate to use in place of the carrier bearing bracket. Cut steel plate to length of the bracket drilling two holes using bracket as a template. Remove bracket and install steel plate.
