Originally Posted by chieflikalotapus
do you have a spray it's cuz i have a toyo mt's and its hard to get in to the crevises on the side due to the lugs on the tire with a sponge. that is why a prefer a spray
If you spray it on you will get it all over your mags
Get a few foam brushes and "paint it " on to avoid the overspray.
If you're that particular about having the best shine....Why would you "F" up your wheels in the process....Doesn't make sense.
Apply like my previous post and you'll achieve the best finish
"QUOTE" P.S. Never spray dressing directly on your tires...Put the nozzle in a sponge and load the sponge up and apply in a circular motion around the tire. Roll the tires a half turn and finish the spot you missed.
Make sure you cover the first tread so you con't look like an amateur....................................
