Re: how to control surge brake?
On my 25 Walkaround I have surge brakes. Do you have a 5 pin connector on your trailer? The 5th wire is for reverse and it should activate a solenoid that prevents your surge brakes from locking. If it does have the solenoid, i would check to see if it is working properly. They do go out from time to time. If not, there should be a pin that you can insert into a hole to disable the surge brakes in reverse.
Made by NISSAN, Built by Americans on May 4, 2004!
Mods:
Detroit Locker Tru-Trac
