Old 04-08-2004, 12:31 AM   #2 (permalink)
bestatchess
Originally Posted by munkeebinis
I know that the 4Runner has some pretty impressive features too like a special kind of diagonally linked suspension that really improves on and offroad performance, and the 8-cyl engine in the 4Runner, although not putting out a monstrous 305hp like the Armada, is no slouch either. So what's the verdict? What are the pros and cons of both?
1. The diagonally linked suspension is a hydraulic line connection of the shocks that is supposed to make it corner flatter at higher speeds by reducing body lean. I don't think it does anything for offroad performance, unless you are doing some high speed off-roading. When I think off-roading, I am thinking how slow can I crawl up or down a rocky trail.
2. The 4Runner optional V8 (as also featured in the Tundra) does not impress, making less HP than the 4Runner's standard V6 for the sake of a little extra torque to raise the towing capacity from 5,000 lbs to 7,000lbs. Sadly, if you opt for the V8, you don't get a transfer case. (No 4WDLo).
