Old 04-07-2004, 11:35 PM   #1 (permalink)
Deepwater
Deepwater's Avatar
I've Got Two New Problems With My Truck
First... My drivers side Window stop working!
It got stuck in the down postion! And would not come up!
The Dealer took my door apart and tested the window. The Tech did some Voltage testing and found out that my complet Window Motor was SHOT!!! They have to Special Order the part!! I did have some luck! They were able to get my window up for me, we are supose to have rain and some snow comming! They said a few days to get this part.
I Hope this isn't going to be a problem with these window motors!!
Second problem is that my Starter is NOT Disengaging!!!
It stays ENGAGED After you trun the key and the Motor is Running!!!!
It sounds like a loud BAN for 2 to 3 seconds after you start the motor! It kind of sounds like if you turned the key to start it while the motor was still running! Like the starter gear hits the fly wheel!!
This really Has ME DOWN!!!
They will have to take the Intake Manafold off to get to the starter!!!
I was really hoping with this truck that I wouldn't have this kind of work NEEDED SO SOON!!! I hope this is with just my truck! And that I'm the only one with these problems!!! I would feel better then anyway!! When you add my radio problem with this, as I'm sure they will have to take the dash apart. Thats just alot of taking apart for me!!! my truck is not two months old!!
Deepwater is offline   Reply With Quote
