Old 05-13-2008, 06:18 PM   #24
IAPharmr
IAPharmr's Avatar
Re: Nitrogen inflated tires...
Originally Posted by Pops
If you really do it, please post the results. I'm assuming it won't make much difference because 35psi of Helium isn't going to be enough weight difference than 35psi of air to make the tires maybe a pound or two lighter which wouldn't be noticeable but it'd sure be nice to know from experience rather than guessing.
Helium won't make a difference, it will not lighten the tire until there is enough Helium in the tire to start to overcome the weight of the tire, which is WAY more then 30 or 40 PSI. It will not make enough difference, it will be like taking the spare change out of your truck. Plus with Helium being a much smaller molecule I am pretty sure you would need a very good seal as it is easier for it to leak out.
IAPharmr is offline   Reply With Quote
