Re: need help installing oem fog lights and kc lights on bull bar......
Originally Posted by slice07
yes it has a larger hole on btm for the nut. i figured that was the only way..... that's goin to b a *****. lol it came with two washers with the rubber on one side. but ok if that's the only way i g uess that'll do.
Yes it was an a***** to install mine!
IF I did it again, I would use longer bolts and then get a big washer for the bottom hole and secure the whole thing from the bottom as opposed to the inside of the westin top bar...
