Originally Posted by roy365
Nothing too bad about it. Just a straight up swap of parts really. Everything should fit good. I am not sure about the Stillen kit's performance, but it is a decent setup for a daily driver looking for more stopping power. My advice is to get a slotted type if you are choosing between slotted and crossdrilled. The drilled are PITA to break in and bed the pads. If you were looking to just end your judder issues and cut down on brake dust then an application like kronos should work fine.
I went all out and installed the Brembo Gran Tourismo 8 piston crossdrilled. I cant even describe the stopping power they provide.
ok I ran a search and did find one for the titan $4,100 sound right?... what does it run? and how big are they compared to say stock ones? I'm getting 20"s this week and am just researching in advance, I'm gonna be running 35x12.5x20 so I'll be needing better brakes eventually
are they for bigger rims? I found these. I thought big rotors were better, but it says nothing about that?
http://www.autocarparts.com/part/194/663/
