Re: 18.7 MPG today
Originally Posted by HudsonValleyTitan
Your friend have a propeller on his beenie? If he's claiming a tiny 28 gallon tank will react the way a huge commecial gasoline holding tank will, his last 30 years have been wasted! The difference in volume, if any at all, would be so miniscule, that it can't even be mentioned w/o being laughed at! If you fill your tank from half or empty...IT'LL MAKE NO FRIGGIN' DIFFERENCE other than the obvious....it costs less to fill from half tank...lol...geez...no wonder this country is on a downhill slope!
LMFAO!
I received the same e-mail a few times last week also. You may encrue a few cents in savings doing this, which will pale in comparision to the time you waste getting gas every time you reach a half of a tank. Same holds true for the little gem (in the same e-mail) that said to SLOWLY fuel up your tank to cut down on vapor  Again, maybe some MINOR savings, but just more time wasted at the pump trying to fuel up slowly. Sad but true that some people fall for anything they read on the internet.
2006 XE KC 4x4, Galaxy Black
Preferred Package, OEM Bug Deflector
Sirius Satellite Radio / IPOD (Plug in kits)
AMSoil 5W-30XL Synth. Motor Oil, OEM Oil Filter
AMSoil Drop in dry air filter/Air Box Mod
AMSoil 75W-140 Severe Gear Rear Diff Fluid
Mobil 1 75W-90 Synthetic Front Diff Fluid
Toyo Open Country AT's P265/70/17
