Old 05-16-2008, 10:44 AM   #7 (permalink)
Megw3788
Megw3788's Avatar
Send a message via AIM to Megw3788
Re: 08.5 Titan 4wd vs. 06 Ford F150 4wd
You guys are acting like some little girl's. You shouldn't break anything since your still completely stock, unless the truck starts jumping up and down, but if it does that then just cut your losses because that's when you start breaking stuff. Just put it in 4low, and ease into the throttle just enough that it isn't letting him pull you backwards, he'll gas it and start spinning, then once he starts spinning you can slowly ease into the throttle and drag his *** around the block. And if you really want to insure your win, weight your truck down alot, then you'll be garunteed to pull him around as long as you don't spin.
Megw3788 is offline   Reply With Quote
