Originally Posted by MoValleyTitan
I installed 325/60/18 on Helos Maxx6 (18x9, +18 offset) with just a leveling kit and I did't have any issues, didn't even have to do a pinch weld mod.
The backspacing on a 9" rim with +18mm of offset is about 5.79". Stock 18s have 5.5" b.s., which explains your success. That and the fact your tires are the shorter 33s ... not 35s. But you if you wanted to, with that b.s., you probably could easily run 35s with the pwm.
