No more fretting; just enjoying!
Originally Posted by CaliforniaTitan
Last Hurrah,
Nope, all of those you describe (3 areas) are normal. Our is like that as well.
The seal around the tails is not needed - when you removed the tailight, the 'seals' are actually where the bulbs plug in.
The rubber strip accross the top of the headlight is there to fill and stop rubbing with the hood.
The rear door seal ends 6" from the bottom of the door but if you open the door you will see the seal across the bottom of the door is what keeps water out.
All is well...dont fret  In our short off-road excursion, we didn't get any water inside.
Chris
Chris,
OK, I will stop fretting and go back to just enjoying. Just seems like with so much stuff on this thing there must be something not quite right!
Glad you stayed dry!
Thanks for the feedback!
Paul
Smoke/Graphite-Titanium:Pop. w Captains Chairs:Big Tow:'mats:Sp'guards + A.R.E Top
[ Mfd:March 2004;order took 46 days]
[ MPG:9.3/12.4/15.7(towing/town/ freeway)(PSI:36/towing 40)]
[ Towing:2007 Jay Flight 25RKS w Prodigy BC & Equal-i-zer Hitch]
