Originally Posted by stnjohnson
The seal around the pump on mine randomly started leaking a couple of weeks ago. When I pulled it off I saw that it's a bit of a weak point. There is also a fluid level sensor at the bottom of the tank that could be leaking. A little bit of shear on either one of those seals would cause them to start leaking. If they give you too much trouble or want to charge you anything for it, just do it yourself. It was a > 30 minute repair. PM me if you end up needing a write up.
Did you repalce this seal yourself? Where is the pump located on the reservoir? Is it at the bottom or 1/3 of the way up?
