Old 05-24-2008, 10:56 PM   #2 (permalink)
scottsbro23
scottsbro23's Avatar
Re: Beating the dead horse levelling kit issue again
Originally Posted by North Country Titan
I know there are dozens of posts about these levelling kits out there, but i'm lost. So straight up ;i have the ncd 2.5 kit on and it makes one hell of a bang when i go over hard bumps like parking lot speedbumps. I'm talking teeth shattering , looking around to see if i've lost any parts bang.I don't recall it doing this before the kit. The noise is happening not on the compression but on the rebound of the shock.
i made sure to ask at the dealership when i had it put on if there was going to be any warranty issues and they said probably not.
I've read it's the strut , the arm , loose nuts etc.. what is the bottom line on these ? Is it the kit thats causing this or bad factory parts? Did anyone elses truck do this before the kit or only after?I want to go to the dealer and give them a heads up on this(there pretty reasonable when it comes to listening to problems !)If it's factory are they covered by the warrantry?
So please somebody give me a straight up answer !
If you have a 4x4 and installed a 2.5" spacer, then it could be what you are feeling and hearing is the Upper control arm hitting the coil bucket as the suspension moves toward full droop.
Happiness Is Beating Bama in Anything, Anytime, Anywhere
"The deadliest weapon in the world is a Marine and his rifle"
scottsbro23 is offline   Reply With Quote
