Re: Transfer case and diff'l fluid change
Rear diff is pretty simple.
On a level surface take a 3/8 drive ratchet. Open the fill plug on the diff cover. Put your catch pan under the diff. Open the drain plug with the 3/8 also. let er drain... Wipe all the metal sludge off the drain plug it has a magnet on it to catch all that nasty junk, take your time getting it clean.
Re insert the drain plug, fill the rear diff to the capacity in the manual I believe it's 2.5 quarts. another way to make sure it's full a little more old skool, fill it ti'll fluid runs out the fill plug, let it stop runing ti'll fluid is just below the hole then plug it.
hope this helps.
Galaxy Black 07 LE
