Thread: Hitch
Old 04-12-2004, 08:38 PM   #3 (permalink)
Sammy Sandbag
Sammy Sandbag's Avatar
Originally Posted by althepa
Can you post some pics of the item you bought?
Are you happy with the quality and fit - how does it compare to the factory item?
Does it come with a mount for the trailer wiring already welded on?
Thanks Al
Sorry I got no digital camera. I provided a link that should have a photo. But in any case, you can barely notice it. It is made from round tubing instead of the straight square tubing and it dips in the middle where the receiver is and back up where it mounts to the frame. I've installed several hitches in the past and this was by far the easiest. But that was mainly due to Nissan's design. There are 6 pre tapped holes for the hitch in the rear of the frame rails. The hidden hitch simply bolts on there using normal hex head bolts, flat washers, and locking washers. Personally I like it better than the factory hitch because it is less noticable, and it's my second Hidden Hitch and am pleased with their quality.
The trailor light plug is not welded on, which gives you the option of what type of plug you want. My trailor uses 4-pin flat, so the round T-1(?) wouldn't do me any good. Most truck accessory stores will carry the plug mount. I prefer stuffing the wire up into the bumper until I need it, less mess to look at that way.
You'll also need a wiring adapter to use the Titan's prewired plug. I just had the dealership order me one for $12.50. I'll get the part number as soon as it comes in.
-Counsel Yourself
