Old 05-27-2008, 09:45 PM   #7 (permalink)
BECHLYF
BECHLYF's Avatar
Re: I wanna go a little bigger...
Originally Posted by Teh Wicked
its not for the looks, its going to be serving a purpose and a 4" lift is in need now.
Im just not sure of which would be the best route to go and if I need new shocks/struts.
I would start with the CST 4" lift spindles, and with the leveling spacers you have now you will have around 6.5" lift. so then you can put blocks in the rears and longer shocks or the deaver mini pack. or you could just run the 4" spindle and remove the leveling spacer kit in front and small blocks in the rears. the really cool thing is you will always use the lift spindles and add upgrades later like coil over shocks etc...
http://www.prgproducts.com/shop/prod..._lift_spindle/
This is the ultimate without going mid-travel
i-wanna-go-little-bigger-parts-pile.jpg  i-wanna-go-little-bigger-after-1.jpg
