Originally Posted by grpape
So is there a big difference between the non slotted rotor and the 5X3 slotted ones (enough to justify spending the extra $$). Is it necessary to change out the rears when doing the fronts? I would like to change the fronts first and later on change out the rears. Which pads would you reccomend with each rotor?
aloha, Derrick
Slotted rotors are not any more warp resistant nor do they last any longer than non slotted rotors, they just slightly increase stopping power. so if you want a little extra stopping power than yes you will want the slotted version. I usually reccomend slotted rotors for people that use their trucks to tow heavy loads. If your truck is just a daily driver, you really dont need slotted rotors.
You dont have to change the rears at the same time as the fronts.
I would reccomend the Hawk LTS compound pads for your truck.
