Originally Posted by CaliforniaTitan
OK,
Went out in the garage because I just can't let anything be 'not finished'.
Ended up mounting the emblem by removing the center portion of the sticky tape on the back. There is revealed 2 'fins' pointing towards you. Drilled a hole in each one straight accross from each other. Broke off the two guiding mounts. Ran a Zip Tie through the rear holes the guiding mounts fit into and over and through the two holes drilled into the emblem and back out the other way. Cinched it up and here are the results:
Chris
yeah, that looks wicked nasty bad!!!
White 2008.5 CC 4x4 BT. PC 6" lift, 3" body lift, 20x10 KMC Monsters, 37x13.50R20 Toyo Open County M/Ts, Magnaflow true dual, K&N CAI, Black GrillCraft mesh grill, UWS toolbox (soon to be black), Chrome step rails (soon to be black), Lloyd custom all weather floor mats, and new gears soon...
