Old 05-28-2008, 08:18 PM   #26 (permalink)
BECHLYF
BECHLYF's Avatar
Re: Installing the 4inch PRG Perf lift tomorrow
Originally Posted by grpape
Do the SAWs have a built in anti bottoming out damper (I guess that's what you would call it)? I think the DRs have something built in so the shock stops before actually bottoming out (I believe I read in a thread). My DRs also make a thud when I put my tire into a fairly deep pot hole. When I check the PRG UCAs, there is no paint missing or scratches in them.
Hey grpape, hows it going man? how much preload do you have ? did you change the bump stops to the thick urethane bumps ? You might be bottoming out the shock. take it easy till you get em.
