Old 06-01-2008, 06:17 AM   #8 (permalink)
loufish
loufish's Avatar
Re: Towed the Boat FINALLY!!!
I am looking to purchase a new boat and want something in the 25' - 30' range. I rele like the Noridic 28' Heat that weighs 4600lbs plus trailer so i estimate the weight around 5500 lbs. My question is what problems if any would i have towing this boat (tow distance could be as much as 1000 miles)?
Make sure the trailer brake system is adjusted correctly....Boats have an advantage over most other trailers in that they are pretty much aerodynamic as opposed to towing a "brick" thru the air...
30 ft boat only about 4600 lbs?...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
