Old 06-03-2008, 07:17 AM   #7 (permalink)
Peytons_Titan08
Peytons_Titan08's Avatar
Re: Intro and Tech question
The lift you are referring to is not that hard to do. The saw's will replace the entire oem coil and spacer. you cant run the spacer and saw's, they have a hat that needs to be on top of the coil bucket. i have this now plus some and love it. included in that you will also need longer break lines, if you decide to add either spacer to oem or saw's you will have hella front rake so a 4" rear block will be needed to get level. at that point you will need a CBDB, carrier barring drop bracket, to lower the drive shaft a little. go for it man, it looks sweet.
2008 Titan XE KC
Exterior:
DeBadged
6000k HID
Performance:
K&N CAI
Audio:
Alpine IDA-X001
JL 300/4 Powering - 4 Polk Audio 6.5"
JL 500/1 Powering - 1 JL 10W3v3
Suspension/Wheels:
Total Chaos Upper Control Arms
4" CST Spindle Lift w/4" Rear Block
Sway-A-Way Coilover's (1" preload)
Sway-A-Way 2.25" Rear's
18" Black/Red Ballistic Offroad Jesters (waiting on delivery) wrapped in 325/65 Terra Grapplers.
"LIFE IS GOOD"
Peytons_Titan08 is offline   Reply With Quote
