Old 04-14-2004, 03:28 PM   #2 (permalink)
dman
dman's Avatar
Say what??? Why don't you just get rid of the exhaust all together, remove air filter, install the Tornado venturi thing, add a quart of STP AND a quart of snake oil, pull out the interior and replace seat with a milk crate, get rid of the bed, remove windows, hood, and fenders. Do all of this and I am sure that you will gain at least another 150 hp and be able to run the 1/4 mile in 10.5 seconds at 128 mph. Oh don't forget to add some stickers with Japanese writing on the remaining body work. You also may want to use some of Hemi777's tips and install your O2 and other miscellaneous sensors into coke bottles. Man you should have one hella fast Titan then. Also consider installing a big *** wing (2 horizontal bars would be best) so that you can create major downforce. I wouldn't want to see you loose control at the high speeds you will be capable of.
Sorry, I am in a fiesty mood today. Just messin' with you man.
dman is offline   Reply With Quote
