Originally Posted by sammy sandbag
Got the Flowmaster 70 installed today. Sounds great. It's got that signature Flowmaster rumble, but quieter than you'd expect. It's actually quieter at idle from the inside than the stocker, but has a good deal more rumble in the 2,000-3,000 range. At the higher RPMs I hear the engine more than the exhaust. When cruising at highway speeds it's actually quieter than stock, probably because of the straight rear exits instead of the turn down. The dual tips come out on either side of the hitch and look awesome. I got 3.5" chrome rolled edge angle cut tips. The installer did a pretty good job, it did take him longer than expected (3 hours.) Not bad considering it was his first Titan. The hardest part was getting the left pipe over the axle and around the spare, but you can't see the pipe, only the tips.
He ran new pipe (2.25 I believe) from the factory flanges behind the cats straight into the mufflers dual inlets, so no Y-pipe anymore. The low end performance actually seems improved. I spun tires accidentally twice as I was driving it home. I'll try and get some picts, maybe a sound clip, and MPG figures later. All this for $300, and a 20 year warranty on the muffler.
Window tint goes on tomorrow.
wow! it has that sig sound and is quiter at idle, to tell you the truth ive never heard of a flowmaster quiter at idle on a big ol v-8 lol. i just looked at their site and its actually longer then the stocker, sweet! thanks fer your input.
let your old age be childlike, and your childhood like old age; that is, so that neither may your wisdom be with pride, nor your humility without wisdom.
