Old 06-05-2008, 12:20 AM   #14 (permalink)
toddwall4
Re: Towed the Boat FINALLY!!!
Originally Posted by loufish
Make sure the trailer brake system is adjusted correctly....Boats have an advantage over most other trailers in that they are pretty much aerodynamic as opposed to towing a "brick" thru the air...
30 ft boat only about 4600 lbs?...
4610 lbs is the dry weight per specs i read...the boat holds 86 gallons in fuel but i have no intentions of towing with a full tank
toddwall4 is offline   Reply With Quote
