Thread: K&N ECU Reset
Old 04-15-2004, 10:19 AM   #2 (permalink)
lizardking
Supporting Vendor (Gold)
Originally Posted by 1BadTitan
Should I reset my ecu after installing the K&N drop in filter? If so, how do I do it? What difference will it make?
You have to unhook the negative side of battery before install...After you complete the entire install then hook battery cable back up... This way you won't get a code and the engine will learn the new set up better...
