Thread: Trailor lights
Old 06-05-2008, 09:08 PM   #11 (permalink)
loufish
loufish's Avatar
Re: Trailor lights
So btw. If you got the fuses under the dash does that mean the recall has or has not been performed? Thanks again.
The two fuses are located in a small sub-harness that goes in between the BCM and the the original trailer wire harness from the BCM....Yes if the fuses/harness is there, the TSB has been completed...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
