Originally Posted by MD_Canteen_Titan
Saw that this was a while ago, and I wanted to check to find out what the result was at the dealer. Did your parking brake need an adjustment? I'm curious because I have the same problem. Whenever I use the parking brake, it goes all the way to the floor, and if I park on an incline, I do get a some rollback. It seems as if the brake may need some tightening.
Sorry for the delay, I didn't see your post. Dealer said it's normal. However, I also had the mushy brake pepal (not parking brake) and I did a tip someone posted on another thread (ignition off, press hard on the brake pedal a few time) and my brake is much better now. I haven't tested on the parking brake but I think this will help.
Like mentioned above, set to neutral first helps.
