Old 04-19-2004, 07:06 PM   #10 (permalink)
bestatchess
Originally Posted by giddyup
Its Much More Simple Than That. Look At The Fuse Box Where The The Fuse Is For The Fog Lights.third Wire Bypass To The Parking Lights Will Give You The Fog Lights On With The Parking Lights.simple, Ive Done It A Few Times.
Exactly what are you proposing? My understanding is that the fog and parking lights are each operated by (1) a microprocessor which, in response to proper positioning of the stalk switches (2) closes a corresponding relay (fog or parking) which (3) closes a circuit to send power through the corresponding fuse (fog or parking). If you jump the leads for the fog and parking relays, won't that turn on the parking lights anytime the fogs are on and vice versa? If you jump the power lead from the fog fuse to the parking fuse, won't that just blow the fuse?
